                                2011/11/12 5:51 GMT-5
check out the corresponding magnetisation M, or if you cannot find that on the web get an approximate Tesla value measured close to the magnet (in a free air case, simple model you can reproduce), and adapt your M of your magnet material to get the same freestanding Tesla value in your example model with COMSOL
                                2013/11/06 3:13 GMT-5
                                                    I have been working with N42 magnets and use a older Gauss meter for measurement as values for plug in values in this way. The unit values in COMSOL are in Webers. I was wondering if the values were transposed properly as I do not see the m being squared or M-2 in non superscript text. Should I be taking the Square root of the Tesla unit? Otherwise, I am still digging into how to set polarity and spatial blotch regions properly.  I appreciate your time and input. COMSOL MULTIPHYSICS is Great. Now all I have to do is figure out how to use it! Independent Researcher, Scott Clark
                                2013/11/06 16:00 GMT-5
                                                    You can find more detailed Information about the magnetization of N42 Magnets on the Internet, for example here:
www.ndfeb-info.com/neodymium_grades.aspx
With that said, you can specfiy the Magnet with a Ampere's Law in the Magnetic Fields Section:
 - Select your Magnet as Domain
 - In the Magnetic Field Section of the Ampere's Law, select Remanent Flux Density as Constitutive relation
 - Set your B_r in the field wich apears
                            You can find more detailed Information about the magnetization of N42 Magnets on the Internet, for example here: http://www.ndfeb-info.com/neodymium_grades.aspx
