Jeff Hiller
COMSOL Employee
6 years ago
2019/07/19 5:03 JST
Updated:
6 years ago
2019/07/19 4:54 JST
Can you upload your mph file?
Jeff Hiller
6 years ago
2019/07/19 13:51 JST
Updated:
6 years ago
2019/07/19 13:48 JST
Yes.
Jeff Hiller
COMSOL Employee
6 years ago
2019/07/19 21:36 JST
Updated:
6 years ago
2019/07/19 21:27 JST
Hi Aashna,
The issue is that before you can subtract a triangle from a rectangle, you need to have a triangle, and in your file there are segments that visually do form a triangle but you have not told the software that you want those three segments turned into a solid triangle. You can do that by converting the three segments into a curve, and then converting the resulting curve into a solid. Then you can select the triangle as the object to subtract from the rectangle.
See the attached file, where I did this for both triangles simulataneously.
PS: If you are starting with COMSOL, I highly recommend binge watching the videos on our Learning Center
Jeff Hiller
Hi Aashna,
PS: If you are starting with COMSOL, I highly recommend binge watching the videos on our [Learning Center](https://www.comsol.com/learning-center)
