Current flowing in resistive material how to find surrounding field
I have a simple model (attached) where I have a aluminum disk that has two contact potentials and current flowing through it. Eventually I would like to add other grounded electrodes in the surrounding space, but as soon as I include a surrounding box that I specify as 'air' COMSOL says it can't solve the problem.
What exactly is going wrong when I just have air surrounding my part? In the attached file, just turn the surrounding cube back to enabled to see what I mean. Thanks!
2 Replies Last Post 2011/11/15 22:44 JST
Posted: 1 decade ago 2011/11/15 17:39 JST
Hi Adam,
in the electric currents application mode COMSOL has problems with zero conductivity domains. So you must assign a very small, but non-zero conductivity to the air dpmain. I tried with 1e-99 S/m and it solves.
Cheers
Edgar
Hi Adam, in the electric currents application mode COMSOL has problems with zero conductivity domains. So you must assign a very small, but non-zero conductivity to the air dpmain. I tried with 1e-99 S/m and it solves. Cheers Edgar
Posted: 1 decade ago 2011/11/15 22:44 JST
Thanks a lot Edgar!
Thanks a lot Edgar!
