How to evaluate a vector integral using Comsol
Hi:
I want to evaluate the integral of Xdx+Ydy+Zdz, which is a vector integral. However, I'm not sure if the line integral in Comsol is evaluating a scalar integral or not. Could someone let me know how to evaluate a vector integral?
Thanks a lot!
4 Replies Last Post 2012/05/02 16:49 JST
Posted: 1 decade ago 2011/11/17 21:52 JST
your notation is not "COMSOL compliant" so I'm not sure I understand what you want.
When you integrate over a line you are using the "implicit" a *ds=sqrt(dx^2+dy^2+dz^2) line integration elementary element that multiplies your formula, hence the gain of [m] for the results, for 2D surface you have the implicit *dx*dy (hence *[m^2], respectively *dx*dy*dz for 3D (hence *[m^3], and not to forget the 2*pi*r*dr for 2D-axi (this is not always the case, you might need to turn the 2*pi*r multiplier "on" manually, see the integration options
Basically you get scalar integrations, so if you need the sum separately for each dx, dy, dz you need to do 3 integrations and sum them. Except if you can write out your equation differently and mighr have COMSOL to solve it directly as an global ODE
Hi your notation is not "COMSOL compliant" so I'm not sure I understand what you want. When you integrate over a line you are using the "implicit" a *ds=sqrt(dx^2+dy^2+dz^2) line integration elementary element that multiplies your formula, hence the gain of [m] for the results, for 2D surface you have the implicit *dx*dy (hence *[m^2], respectively *dx*dy*dz for 3D (hence *[m^3], and not to forget the 2*pi*r*dr for 2D-axi (this is not always the case, you might need to turn the 2*pi*r multiplier "on" manually, see the integration options Basically you get scalar integrations, so if you need the sum separately for each dx, dy, dz you need to do 3 integrations and sum them. Except if you can write out your equation differently and mighr have COMSOL to solve it directly as an global ODE -- Good luck Ivar
Posted: 1 decade ago 2011/11/23 6:58 JST
I have a 2D transient acoustic solid interaction model. I want to integrate the pressure along a cylinder to find the force - the circle in the geometry (with thickness H). I am only interested in the X component of the force. The expression I want to integrate (a line integral around the circle) is force = H*integral over L p(x,y)*dot(N(x,y),I)*ds, whre N is the outward normal vector of the circle and I the standard basis vector in the X direction, I = [1, 0].
I am having difficulty converting this vector expression into a scalar one for Comsol's use, specifically how to apply some kind of vector dot product operator. The closest thing I can come up is to set the integrand to p*sys1.e_1*nx, but I understand this product sys1.e_1*nx is not mathematically equal to the dot product.
Thanks for the help!
I have a 2D transient acoustic solid interaction model. I want to integrate the pressure along a cylinder to find the force - the circle in the geometry (with thickness H). I am only interested in the X component of the force. The expression I want to integrate (a line integral around the circle) is force = H*integral over L p(x,y)*dot(N(x,y),I)*ds, whre N is the outward normal vector of the circle and I the standard basis vector in the X direction, I = [1, 0]. I am having difficulty converting this vector expression into a scalar one for Comsol's use, specifically how to apply some kind of vector dot product operator. The closest thing I can come up is to set the integrand to p*sys1.e_1*nx, but I understand this product sys1.e_1*nx is not mathematically equal to the dot product. Thanks for the help!
Posted: 1 decade ago 2011/11/23 15:43 JST
isn't it simply "p*nx" you need to integrate ? nx being the normal at any point (x,y) or "s" along the edge, while "p" is always normal to the boundary (edge in your 2D case)
Check it out with a few coordinate plots and simple test integration, you should also check the signs depending on how you handle the analysis, if you use "s" it might revert on close loops
Hi isn't it simply "p*nx" you need to integrate ? nx being the normal at any point (x,y) or "s" along the edge, while "p" is always normal to the boundary (edge in your 2D case) Check it out with a few coordinate plots and simple test integration, you should also check the signs depending on how you handle the analysis, if you use "s" it might revert on close loops -- Good luck Ivar
Posted: 1 decade ago 2012/05/02 16:49 JST
I'm starting a new job and I'm using Comsol (I'm a novice user) but I need to be able to integrate a vector function. I have looked at the reference guide and I only found how to integrate a scalar (complex or real). As an example, we need to compute the following integral (in latex form) :
\frac{1}{\lambda(\Omega)} \int_{\Omega} \vec{f}(x) d\lambda_x
where f is a vector function in \mathbb{R}^N with N=3 or 4, given by
f(x) = [ x, y, z, 1] (cartesian coordinate)
Until now, i use the call to 'postint' with some trick in order to limit the number of call :
cmplx1 = postint( fem, 'x+j*y', 'unit', 'm^4', 'recover', 'off', 'dl', k );
cmplx2 = postint( fem, 'z+j*1', 'unit', 'm^4', 'recover', 'off', 'dl', k );
The final objectives is to obtain the centroids of \Omega. Before that, we used 4 call to 'postint' but now, we want to reduce the number of call to a single one because it seems to be possible and less expensive in CPU time. In our application we have to compute a significant number of centroids coordinates, that's why we need to solve this problem.
Thank you for your help.
Hi, I'm starting a new job and I'm using Comsol (I'm a novice user) but I need to be able to integrate a vector function. I have looked at the reference guide and I only found how to integrate a scalar (complex or real). As an example, we need to compute the following integral (in latex form) : \frac{1}{\lambda(\Omega)} \int_{\Omega} \vec{f}(x) d\lambda_x where f is a vector function in \mathbb{R}^N with N=3 or 4, given by f(x) = [ x, y, z, 1] (cartesian coordinate) Until now, i use the call to 'postint' with some trick in order to limit the number of call : cmplx1 = postint( fem, 'x+j*y', 'unit', 'm^4', 'recover', 'off', 'dl', k ); cmplx2 = postint( fem, 'z+j*1', 'unit', 'm^4', 'recover', 'off', 'dl', k ); The final objectives is to obtain the centroids of \Omega. Before that, we used 4 call to 'postint' but now, we want to reduce the number of call to a single one because it seems to be possible and less expensive in CPU time. In our application we have to compute a significant number of centroids coordinates, that's why we need to solve this problem. Thank you for your help.
