How to calculate average radial concentration vs axial length?
Geometry: Simple rectangle (cartesian coordinates) width>height
Model: Transport of diluted species - time dependent
I have solved the equivalent of Taylor dispersion in a rectangular channel as a function of time. In order to compare with Taylor's analytical expression, I need to determine the average concentration in the y direction as a function of x for a given time. Using a Cut Line 2D I am able to plot the concentration for all x for a given y position or vise versa, but I cannot figure out how to average the concentration in the y direction for a given time and plot as a function of x.
Therefore, I would be much appreciative if someone could describe step by step how to do this. I have been through every COMSOL manual and cannot find a single description of this type of result manipulation.
2 Replies Last Post 2012/04/14 8:17 JST
Posted: 1 decade ago 2011/11/17 21:43 JST
you have the "Definition - Model Couplings - Linear or general projection" operator to integrate over a line or curve and make a field variable you can access at another spatial position, check the doc
Hi you have the "Definition - Model Couplings - Linear or general projection" operator to integrate over a line or curve and make a field variable you can access at another spatial position, check the doc -- Good luck Ivar
Posted: 1 decade ago 2012/04/14 8:17 JST
Hi Ivar :)
I have the same issue, and I'd love if you could elaborate a little more your answer, because the document doesn't help. I have a square channel with a free and porous media flow, and I want to find the average velocity of the fluid over the length of the channel. Now, I created the Linear projection as you indicated and selected first the domain and the vertices of the source face and the destination face and nothing, then I tried with the boundary, and nothing.
Is there a way of getting the average of each "slide" of a variable per length differential increment so I can plot that average against the lenght coordinate? Please help :)
Thanks a lot :)
[QUOTE] Hi you have the "Definition - Model Couplings - Linear or general projection" operator to integrate over a line or curve and make a field variable you can access at another spatial position, check the doc -- Good luck Ivar [/QUOTE] Hi Ivar :) I have the same issue, and I'd love if you could elaborate a little more your answer, because the document doesn't help. I have a square channel with a free and porous media flow, and I want to find the average velocity of the fluid over the length of the channel. Now, I created the Linear projection as you indicated and selected first the domain and the vertices of the source face and the destination face and nothing, then I tried with the boundary, and nothing. Is there a way of getting the average of each "slide" of a variable per length differential increment so I can plot that average against the lenght coordinate? Please help :) Thanks a lot :)
