Different Result ! Boundary surface and cut-plane
Posted 2019/08/17 19:16 JST General, MEMS & Piezoelectric Devices, Computational Fluid Dynamics (CFD) Version 5.4 1 Reply
I have a simple T-junction micro-mixer
Geometery: 200*200 micrometer - lenght 2.7 mm
Concentration Contour at outlet boundary using "surface" :
Concentration Contour at outlet boundary using "cut-plan" :
The problem is that when I use boundary surface for exctracting results I attain some results which are compeletly different from when I use cut-plan at same location. As you see in pictures, concentration countors are not identical in quantities and distribution! What is the problem? and why? would you please recommand a solution?
Sincerely,
