Functional of Energy calculation
Sorry for my simple question, because I'm a new in COMSOL. I would like to get a sequence of meshes for some elliptic boundary problem, say, for the Poisson problem with Diriechlet conditions, and a sequence of functionals of energy for each mesh. I'm interested in investigation of increasing of the values of functional under refining mesh.
4 Replies Last Post 2011/11/23 17:37 JST
Posted: 1 decade ago 2011/11/23 16:38 JST
you can use a parameter for the mesh density, in most fields in the GUI you can use variables, not only constants
Hi you can use a parameter for the mesh density, in most fields in the GUI you can use variables, not only constants -- Good luck Ivar
Posted: 1 decade ago 2011/11/23 16:48 JST
Thank you, Ivar. I understand the way of using parametric meshes, but I wonder, if the calculation of the functional of energy is an embedded function of COMSOL or it should be entered by some programming?
Posted: 1 decade ago 2011/11/23 17:12 JST
I believe, if you work in pure "math" PDE mode that you must write out your equations yourself, by integrating over your domain but why should that be an issue ?
In most "physics" pre-cooked situations, you have numerous internal variables you might choose from, or make your own, as needed
But now I'm not 100% sure I fully understand what you are after ...
Hi I believe, if you work in pure "math" PDE mode that you must write out your equations yourself, by integrating over your domain but why should that be an issue ? In most "physics" pre-cooked situations, you have numerous internal variables you might choose from, or make your own, as needed But now I'm not 100% sure I fully understand what you are after ... -- Good luck Ivar
Posted: 1 decade ago 2011/11/23 17:37 JST
Ok, I see from your answer, that I should calculate a functional as an integral over the domain and this integration is not an embedded function of COMSOL. I think, you understood me correctly. Thanks.
