Stress Plot Formation
When I go to plot stresses, does Comsol use nodal averaging or are these stresses element-based? Can I choose which to use?
Thank you in advance,
Theodore
4 Replies Last Post 2011/11/29 1:13 JST
Posted: 1 decade ago 2011/11/28 4:54 JST
check the doc, you have many sress elements for different cases
Hi check the doc, you have many sress elements for different cases -- Good luck Ivar
Posted: 1 decade ago 2011/11/28 5:58 JST
Hi Ivar,
I've been reading through the documentation for a while and cannot find anything. Can you explain what you mean by "many stress elements for different cases"?
Thank you,
Theodore
Hi Ivar, I've been reading through the documentation for a while and cannot find anything. Can you explain what you mean by "many stress elements for different cases"? Thank you, Theodore
Posted: 1 decade ago 2011/11/28 13:07 JST
The default stress plot is nodal averaged or “Smoothed”. You can change that to element based by setting Smoothing=None in the Quality tab of the result plot. COMSOL also has a more accurate stress recovery algorithm, based on the superconvergent patch recovery technique, which you can activate by selecting Recover=”Within domains”, also in the Quality tab.
Nagi Elabbasi
Veryst Engineering
The default stress plot is nodal averaged or “Smoothed”. You can change that to element based by setting Smoothing=None in the Quality tab of the result plot. COMSOL also has a more accurate stress recovery algorithm, based on the superconvergent patch recovery technique, which you can activate by selecting Recover=”Within domains”, also in the Quality tab. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2011/11/29 1:13 JST
Thank you Nagi. That helped tremendously. I knew it was in there somewhere.
-Theodore
Thank you Nagi. That helped tremendously. I knew it was in there somewhere. -Theodore
