Negative sound pressure levels over a certain frequency
I am testing the sound pressure levels of a piezo transducer (using PZT-4 as piezo transducer) at different frequencies.
The one used is: https://www.steminc.com/PZT/en/piezoelectric-disc-25x85mm-s-235-khz
And, when simulating the sound pressure levels I get negative result above 142 kHz. The resonans frequency for this piezoelectric-disc is 235 kHz.
Does anybody know where I did something wrong?
Best regards, Kim
The Generated Graph of Frequencies
2 Replies Last Post 2019/10/06 0:08 JST
Posted: 6 years ago 2019/10/05 18:49 JST
Kim,
you are plotting dB, that is 10*log10(p/pref). So the sound pressure level is not turning negative, only very small.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Kim, you are plotting dB, that is 10*log10(p/pref). So the sound pressure level is not turning negative, only very small. Cheers Edgar
Posted: 6 years ago 2019/10/06 0:08 JST
Updated: 6 years ago 2019/10/05 20:08 JST
Edgar,
Thank you very much! I must have had a late nigth out yesterday ...
Cheers Kim
Edgar, Thank you very much! I must have had a late nigth out yesterday ... Cheers Kim
