Stress linearisation along any arbitrary path
Hello, I wonder if there is a means to do stress linearisation during post processing along any arbitrary path intersecting the structure? The existing stress linearisation node allows selection of only predefined edges. Abhishek
2 Replies Last Post 2019/11/04 15:05 JST
Posted: 6 years ago 2019/11/01 15:59 JST
Updated: 6 years ago 2019/11/01 15:59 JST
Hi Abishek,
Stress linearization requires a geometrical line. If it is problematic to insert a new line, for example because you have a large complex geometry or that the solution takes a long time, then a good idea is to use one or more submodels for the stress linearization evaluations.
How to set up submodels is shown in for example: https://www.comsol.com/model/submodeling-analysis-of-a-shaft-20359 https://www.comsol.com/model/submodel-in-a-wheel-rim-8517
Henrik
Henrik Sönnerlind
COMSOL
Hi Abishek, Stress linearization requires a geometrical line. If it is problematic to insert a new line, for example because you have a large complex geometry or that the solution takes a long time, then a good idea is to use one or more submodels for the stress linearization evaluations. How to set up submodels is shown in for example: Regards, Henrik
Posted: 6 years ago 2019/11/04 15:05 JST
Dear Henrik,
Thank you for the reply. I am quiete surprised that COMSOL being such a user friendly software doesn't provide this crucial tool (as far as pressure vessel design is concerned), while softwares like ABAQUS and ANSYS provide such a functionality since a long time.
Is there any add-in which can do the stress linearisation after the stresses have been extracted using cut line 3D option?
Regards Abhishek
Dear Henrik, Thank you for the reply. I am quiete surprised that COMSOL being such a user friendly software doesn't provide this crucial tool (as far as pressure vessel design is concerned), while softwares like ABAQUS and ANSYS provide such a functionality since a long time. Is there any add-in which can do the stress linearisation after the stresses have been extracted using cut line 3D option? Regards Abhishek
