Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
2 decades ago
2010/01/07 0:25 JST
Ravi, I have not actually tried to run your model file, but I have a guess as to the problem. If the problem runs at steady state, then I suspect the time step is getting too large during the transient solution. What does the log file show during the solution ? What is the maximum Courant number at the time of failure ? Where does it occur ? Two recommendations: 1) keep the time-step smaller than a Courant number of 1 by either reducing the time step or increasing the mesh spacing, 2) gradually increase the Courant number by controlling the time step. The solution must converge at each time step similarly to the convergence at steady state. You also may need to adjust artificial dissipation. Even for low Reynolds number, the default GLS method will yield consistent results.
2 decades ago
2010/01/07 9:43 JST
Thanks James for the suggestions.
Pardon me, I might be asking very basic question. As I said I am quite new to COMSOL. I don't know how about the Courant number, the log file just says this,
Time 0.9692946724378361:
Nonlinear solver interrupted since convergence rate above limit.
I assumed 0.0001 is small enough time step, I might be wrong. Could you please refer to portion of manual where I can understand more about Courant number and controlling the time step.
Thank you for your help.
Ravi
Ravi
Jim Freels
2 decades ago
2010/01/08 7:50 JST
Courant number is a classic parameter used in numerical analysis of systems that is independent of COMSOL. Courant number is not displayed or printed out as a standard variable in COMSOL, but can be by creating the variable and displaying it graphically if you want.
Think of a fluid particle flowing through a finite element in a single direction. This allows one to think of the finite element in a single dimension. If the time-step algorithm is explicit, then we know that we must restrict the Courant number to about half of unity (1/2). The simplest way to describe this is to think that the fluid particle cannot completely pass through the finite element in less than a single time step,
C = V dt / dx < 0.5
COMSOL is using superior implicit time stepping so that you should be able to use larger time steps and exceed the Courant limit; especially as the solution approaches steady state. However, one can be conservative and assured of stability if the Courant number is less than 0.5; especially during the initial part of a transient or a fast-moving portion of an established transient.
Expanding your thought process to 3D brings out different formulations (and names) for the Courant number, but the basic idea is the same. Google the string "Courant number' and it will yield some interesting links.
C = V dt / dx < 0.5
2 decades ago
2010/05/18 16:23 JST
I'm having a similar problem in that I'm very new to COMSOL.
My task is to model both laminar and turbulent flow past a cylinder.
I've done this following a given laminar model that works, but when I change the parameters such as geometry of the cylinder to try and achieve turbulent flow, the program starts giving me the "doesn't converge" statement.
What am I doing wrong?
Is it the solver that I'm using?
Thanks!
Thanks!
2 decades ago
2010/05/20 0:33 JST
(V3.5)
you start the ramp after 0.9 s, reaching Umax 0.2 s later?
I had no problem getting a time dependant solution without using your ramp.
I used a scaled stationary solution at 0.3 m/s instead.
Left boundary: 4*s*(1-s)*Umax (without the ramp)
Initial conditon: Uinitial: u/0.3, (use the stored stationary solution at u = 0.3)
No artificial solution.
Solver settings: time steps free (~0.3 s).
The vortex street developed after ~ 50 s.
(V3.5)
2 decades ago
2010/06/01 4:55 JST
I have tried going through this file. I am trying to use a ramped boundary condition for my problem.
I am new to COMSOL. Can you please tell me what are variables 's' and 't' in your model?
Thank you for your time
