Filling void space in assembly
I have a welded assembly that I have imported from Creo 5 that is a water-cooled part. I want to simulate the distortion from the internal space due to the water pressure. I've tried searching for this info without luck.
Can I somehow fill this internal volume with a domain and apply a volume pressure constraint, or set the new domain to water and apply a pressure constraint? Or do I need to create a volume in Creo that represents the water cooling space and then assign material/constraints to it? Part of the reason I'm asking is I don't see how to select a domain that is internal to the assembly.
Thanks. --m
1 Reply Last Post 2019/11/15 11:09 GMT-5
Jeff Hiller COMSOL Employee
Posted: 6 years ago 2019/11/15 11:09 GMT-5
Updated: 6 years ago 2019/11/15 6:10 GMT-5
Hi Mike,
You can use Cap Faces to create the fluid domain (See for instance this thread or search the Discussion Forum for "Cap Faces" for more details).
With that said, if your only motivation for that is to apply the pressure load applied by the fluid onto the solid and the pressure is known a priori (as in, you are not also running a CFD analysis to compute the pressure distribution), then you don't need to add a computational domain for the fluid, you can just apply a pressure boundary condition on those surfaces where the pressure acts onto the solid.
Jeff Hiller
Hi Mike, You can use Cap Faces to create the fluid domain (See for instance [this thread](https://www.comsol.com/forum/thread/241541/create-cfd-mesh-from-cad-geometry?last=2019-08-27T17:39:06Z) or search the Discussion Forum for "Cap Faces" for more details). With that said, if your only motivation for that is to apply the pressure load applied by the fluid onto the solid and the pressure is known a priori (as in, you are not also running a CFD analysis to compute the pressure distribution), then you don't need to add a computational domain for the fluid, you can just apply a pressure boundary condition on those surfaces where the pressure acts onto the solid. Best, Jeff
