Solid Mechanics: Estimating change in out-of-plane thickness in 2D model
Posted 2011/12/09 5:08 JST Geometry, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers, Structural Mechanics Version 4.2 4 Replies
Hello. I am trying to approximate an abrupt change in thickness in an otherwise planar part. The local increase in thickness is due to a reinforcement. I have really only found one approach, which involves modifying the modulus proportionally to the thickness, such that a region with twice the thickness would have a doubled modulus. Unfortunately, this does not work on a few initial trials, whether applied as a discontinuous change, i.e. two domains with different modulus but otherwise identical properties, or as a varying smooth transition.
I understand that a discontinuous modulus results in discontinuous displacement, etc. which is why it wouldn't solve, but are there other ways to do this since, in reality, the displacement is obviously not discontinuous, albeit gradients may be rather sharp.
I would like to avoid 3D modeling for a number of reasons, so please keep suggestions to the 2D domain.
4 Replies Last Post 2011/12/10 17:53 JST
