extracting information with mphinterp() - ndgrid vs meshgrid
I could not easily find anything about this topic, so excuse if I missed something.
In page 288 of the LiveLinkForMATLABGuide, there's an example of how to extract information using mpheval() with coordinates. The example states to use:
x0 = [0,1e-2,2.5e-2,5e-2]; y0 = x0; z0 = [5e-3,1e-2,1.1e-2];
[x,y,z] = meshgrid(x0,y0,z0); xx = [x(:),y(:),z(:)]';
T = mphinterp(model,'T','coord',xx);
which gives a (3,N) vector for coordinates (first index marks x, y, or z). The quantity returned, T, has the same size (3,N). Suppose I now want to view the result of one slice (say the x-z plane, for y=2.5e-2). The question is, how can I reshape() T into a (3,Nx,Ny,Nz) tensor, where then I could select all the x-coordinates of T for Ny=2, i.e. in MATLAB:
T3D(1,:,2,:);
After lots of digging around, I found that meshgrid() is not the correct function for this, but one should use ndgrid() instead. Here's an example MATLAB script to show this. We expect the coordinates of an axis to be equal in its plane regardless of where we slice. In other words, the 2D matrix of the x or z coordinate of the x-z plane for arbitrary y, should be equal:
clc;
x0 = [11,12];
y0 = [21,22,23];
z0 = [31,32,33,34];
[x,y,z] = ndgrid(x0,y0,z0); %% works!
%[x,y,z] = meshgrid(x0,y0,z0); %% doesn't!
coords = [x(:),y(:),z(:)]';
xyz = reshape(coords,3,numel(x0),numel(y0),numel(z0));
disp('x-y (x along z)'); % x-y plane, x coordinates, along z
x1=squeeze(xyz(1,:,:,1));
x2=squeeze(xyz(1,:,:,2));
x3=squeeze(xyz(1,:,:,3));
x4=squeeze(xyz(1,:,:,4));
all(x1(:)==x2(:)) && all(x3(:)==x3(:)) && all(x3(:)==x4(:))
disp('x-y (y along z)'); % x-y plane, y coordinates, along z
x1=squeeze(xyz(2,:,:,1));
x2=squeeze(xyz(2,:,:,2));
x3=squeeze(xyz(2,:,:,3));
x4=squeeze(xyz(2,:,:,4));
disp('x-z (x along y)'); % x-z plane, x coordinates, along y
x1=squeeze(xyz(1,:,1,:));
x2=squeeze(xyz(1,:,2,:));
x3=squeeze(xyz(1,:,3,:));
disp('x-z (z along y)'); % x-z plane, z coordinates, along y
x1=squeeze(xyz(3,:,1,:));
x2=squeeze(xyz(3,:,2,:));
x3=squeeze(xyz(3,:,3,:));
disp('y-z (y along x)'); % y-z plane, y coordinates, along x
x1=squeeze(xyz(2,1,:,:));
x2=squeeze(xyz(2,2,:,:));
all(x1(:)==x2(:))
disp('y-z (z along x)'); % y-z plane, y coordinates, along x
x1=squeeze(xyz(3,1,:,:));
x2=squeeze(xyz(3,2,:,:));
all(x1(:)==x2(:))
Just to finalize, here's an example of how I extract the x-z plane of the By magnetic field component at the first and last y index, in MATLAB, in my code:
[Bx,By,Bz, unit] = mphinterp(model,{'mf.Bx','mf.By','mf.Bz'},'dataset','dset1','coord',coords/lu,'solnum',1); % solnum referes to initial time
By3D = reshape(By,NDx,NDy,NDz);
figure; imagesc(squeeze(By3D(:,1,:)));
figure; imagesc(squeeze(By3D(:,end,:)));
lu is the length unit used in COMSOL (I converted everything to meters). NDx,NDy,NDz are the vector lengths of the original x,y,z coordinate vectors. Hope this helps!
0 Replies Last Post 2019/11/22 4:21 GMT-5
Hello Roy Shiloh
