2011/12/16 5:17 JST
try it out, take a simple case i.e with a cylinder in 2D-axi, define a material conductivity as "sigma(z)" or for example:
sigma0 + sigma_slope * ( z - z0 ) / ( Ztop - Zbottom )
(since the axis in 2d-axi is along Z this should vary the conductivity along the axis), apply a constant current and check the voltage
here z0 is the starting point for z calculation, Ztop and Zbottom the Z coordinates of the cylinder top and bottom, hence the difference is the cylinder length
I believe this should work like that, I cannot check as I'm not now in front of my COMSOL WS ;)
2011/12/16 6:16 JST
It works, Thanks a million!!!
2012/04/17 21:02 JST
Hi Ivar.
I want to model a material which its properties are varying according to the spatial coordinates (x, y, z). The material has temperature dependent properties. In COMSOL 4.2 how can I do this task? I am new in COMSOL and I need the detailed comments.
Regards.
Hi Ivar.
Regards.
2014/02/25 2:55 JST
I have the same problem but I can't fix it by using the same procedure.
I have a 2D rectangle and I want to change the thermal conductivity along the x axis as a function of x.
I changed the predefined thermal conductivity with both expressions: "k(x)" and "k0+k_slope*(x-x0)/(xinitial-xfinal)". when I used the second one I also defined in Model->Definitions k0, k_slope, xinitial and xfinal but it doesn't work.
Am I missing something? Do I have to define anything else?
Thank you very much for your help,
Edoardo
Edoardo
