solving multiphysics problems
Kartikeyan Ramachandran
sir,
i am trying to solve a multiphysics problem which includes heat transfer and fluid flow . but when i solve all my equations together ,the solution is not converging. so i tried to solve sequentially. but i do not know how to link each solution to other module.for example after solving for heat transfer i cannot use that solution to compute velocities in laminar flow module.
please help......,
1 Reply Last Post 2011/12/20 17:17 JST
Posted: 1 decade ago 2011/12/20 17:17 JST
have you checked the "Conjugate Heat Flow" section of them physics and the related doc ? be aware that coupling these two physics is tricky, and require careful tweaking (= reasonable knowledge of expected results to define "good" initial values)
Hi have you checked the "Conjugate Heat Flow" section of them physics and the related doc ? be aware that coupling these two physics is tricky, and require careful tweaking (= reasonable knowledge of expected results to define "good" initial values) -- Good luck Ivar
