NaN for a paramter study using probes
I am getting the same error as posted above. Has anyone found a solution?
The issue: I want to do a parameter sweep and using probes I want to populate a table. One way to do so is populate the table with the probe values as I sweep. However, I am running COMSOL on a cluster where it just solves and I need to post process the data to make the table. The issue is for a certain probe, I get NaN values for all the sweep points except the last one.
Best, Hitesh
1 Reply Last Post 2020/01/17 12:14 JST
Posted: 5 years ago 2020/01/17 12:14 JST
Hi, Which probe are you using? I have used cut pint 3D to plot data into Origin lab. At that time software return NaN error (Not a number). After looking for many information for many days, I just realized that my unit is wrong so the dot it out of the geometry.
