natural convection
hi all.
this is problem about natural convection.
first, the file I attached, free_convection.mph, is from model gallery. so it works very well. this model has low and high temperature in right and left sides of square.
second, free_convection_modified.mph has low and high temperature in top and bottom of square.
almost are same with "free_convection.mph".
but the result is very strange, the result should be like this " www.youtube.com/watch?v=nveHV29gD-E "
do you guys know what problem is?
ByungDal
5 Replies Last Post 2012/02/09 16:08 JST
Lechoslaw Krolikowski
Posted: 1 decade ago 2011/12/20 22:12 JST
I think that you should base on the following example:
Model Library>Heat Transfer Module>Tutorial Models<cold_water_glass,
if you want to simulate natural convection.
Andrzej
Hi, I think that you should base on the following example: Model Library>Heat Transfer Module>Tutorial Models
Posted: 1 decade ago 2011/12/22 5:48 JST
This is an interesting problem that you’re trying to analyze. It is an unstable Rayleigh-Benard convection problem. I think you need a much finer mesh and a transient analysis for reach Ra value. To see if the basic settings you have are reasonable I tried switching the hot/cold boundaries to the side walls instead of the top and bottom boundaries and it works as expected (it’s a different problem of course, but one that is much more stable).
Nagi Elabbasi
Veryst Engineering
This is an interesting problem that you’re trying to analyze. It is an unstable Rayleigh-Benard convection problem. I think you need a much finer mesh and a transient analysis for reach Ra value. To see if the basic settings you have are reasonable I tried switching the hot/cold boundaries to the side walls instead of the top and bottom boundaries and it works as expected (it’s a different problem of course, but one that is much more stable). Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2011/12/22 18:16 JST
thank you for your advice.
but I can't understand about using transient analysis for reach Ra.
thank you
thank you for your advice. but I can't understand about using transient analysis for reach Ra. thank you
Posted: 1 decade ago 2011/12/23 23:33 JST
I meant for "each" Ra value. The solutions are not trivial, and the convection patterns are not unique. You can also see that in the animation you referred to. A transient analysis is more suitable as it can capture the gradual development of the convective flow.
Nagi Elabbasi
Veryst Engineering
I meant for "each" Ra value. The solutions are not trivial, and the convection patterns are not unique. You can also see that in the animation you referred to. A transient analysis is more suitable as it can capture the gradual development of the convective flow. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2012/02/09 16:08 JST
Hi ..
i tried modifying the same problem to 3D with a slightly different geometry.
But i ended up in error statement : "Detail: NaN_or_Inf_found_when_solving_linear_system_using_GMRES"
may i know what mistake(s) did while setting up the problem ?
Hi .. i tried modifying the same problem to 3D with a slightly different geometry. But i ended up in error statement : "Detail: NaN_or_Inf_found_when_solving_linear_system_using_GMRES" may i know what mistake(s) did while setting up the problem ?
