Difference between mf2.Bx/y/z and mf2.normB
Sanchayan Rajeetharan
Hi.
Im working on building 3D gradient coil. When im plotting magnetic flux density im confused with mf2.Bx/y/z and mf2.normB. I need to plot resultant magnetic flux density on X & Y & Z axis. can anyone help.
2 Replies Last Post 2020/02/12 6:52 JST
Lars Dammann COMSOL Employee
Posted: 6 years ago 2020/01/31 0:22 JST
mf.Bx, mf.By and mf.Bz are the x-, y,- and z-component of the magnetic flux density vector. mf.normB is the norm of that vector, which (simply speaking) is sqrt(mf.Bx^2+mf.By^2+mf.Bz^2).
If you are working in the frequency domain, it is actually the complex norm of the vector, which is more like:
sqrt(mf.Bx*conj(mf.Bx)+mf.By*conj(mf.By)+mf.Bz*conj(mf.Bz))
but you probably don't need to worry about that difference.
Hope that helps, Lars
Hi, mf.Bx, mf.By and mf.Bz are the x-, y,- and z-component of the magnetic flux density vector. mf.normB is the norm of that vector, which (simply speaking) is sqrt(mf.Bx^2+mf.By^2+mf.Bz^2). If you are working in the frequency domain, it is actually the complex norm of the vector, which is more like: sqrt(mf.Bx*conj(mf.Bx)+mf.By*conj(mf.By)+mf.Bz*conj(mf.Bz)) but you probably don't need to worry about that difference. Hope that helps, Lars
Posted: 6 years ago 2020/02/12 6:52 JST
sqrt(mf.Bxconj(mf.Bx)+mf.Byconj(mf.By)+mf.Bz*conj(mf.Bz))
Now I understood. Thanks
>Hi, > >mf.Bx, mf.By and mf.Bz are the x-, y,- and z-component of the magnetic flux density vector. mf.normB is the norm of that vector, which (simply speaking) is sqrt(mf.Bx^2+mf.By^2+mf.Bz^2). > >If you are working in the frequency domain, it is actually the complex norm of the vector, which is more like: > > sqrt(mf.Bx*conj(mf.Bx)+mf.By*conj(mf.By)+mf.Bz*conj(mf.Bz)) > >but you probably don't need to worry about that difference. > >Hope that helps, >Lars Now I understood. Thanks
