problem with solving and material
I'm trying to simulate the heat transfer of radiation in a pipe to a fluid, but I'm having problem with the solving and material. I'm using the steel aisi 4340 for the pipe and when compute my model the following error occur:
Failed to evaluate variable Jacobian.
- Variable: material.parameter.mu
- Geometry: 1
- Domain: 1
What I can do?
My model is in attach.
I await response.
Gustavo.
4 Replies Last Post 2011/12/25 16:17 JST
Posted: 1 decade ago 2011/12/23 21:58 JST
first of all are you sure you have that much "radiation" from a solid to a fluid, compared to conduction and convection ? In particular for your dimensions ?
Have you done a few hand estimates ? these one should always do, even just to chekc that the FEM model is set up correctly
Then if you check your material properties, you will see that a few items are missing, that is why you get the error message
Last thing, when you have such large extend objects, to make the selection and model set up (sometimes too the model post-processing) its is worth to use a second "Definition View" where you have unchecked the "View - Camera - Preserve Aspect ratio" tick box (then update your plots)
Hi first of all are you sure you have that much "radiation" from a solid to a fluid, compared to conduction and convection ? In particular for your dimensions ? Have you done a few hand estimates ? these one should always do, even just to chekc that the FEM model is set up correctly Then if you check your material properties, you will see that a few items are missing, that is why you get the error message Last thing, when you have such large extend objects, to make the selection and model set up (sometimes too the model post-processing) its is worth to use a second "Definition View" where you have unchecked the "View - Camera - Preserve Aspect ratio" tick box (then update your plots) -- Good luck Ivar
Posted: 1 decade ago 2011/12/24 2:48 JST
Hi Ivar
The solid receive the solar radiation and than the fluid receive heat by convection. So i think the correct physics that I have to use are: laminar flow and heat transfer with radiation in participating media.
I corrected the error with material properties.
Its a good idea the view without Preserve Aspect ratio. I did not know this option.
Thanks.
Gustavo
Hi Ivar The solid receive the solar radiation and than the fluid receive heat by convection. So i think the correct physics that I have to use are: laminar flow and heat transfer with radiation in participating media. I corrected the error with material properties. Its a good idea the view without Preserve Aspect ratio. I did not know this option. Thanks. Gustavo
Posted: 1 decade ago 2011/12/24 5:03 JST
if it's the external surface that receives solar radiation, you do not need "radiation" in HT, you can use the total heat flux from the sun [W/m^2], somewhere <1500[W/m^2], depending on altitude, sun orientation and air humidity (atmostphere transmission).
The radiation is for radiative exchange between surfaces with stephan Boltzmann law and T^4 behaviour, mostly its negligible for temperatures below a few hundred K, compared to convection and conduction (except perhaps in vacuum when you have no conduction nor convection in the vacued region, but still thermal radiative exchange between internal surfaces)
Hi if it's the external surface that receives solar radiation, you do not need "radiation" in HT, you can use the total heat flux from the sun [W/m^2], somewhere
Posted: 1 decade ago 2011/12/25 16:17 JST
thanks Ivar
thanks Ivar
