How to calculate farfield by nearfield?
I'm simulating a metalens, and I want to know the field behind the lens surface. If I just calculate the field of whole space, I would run out of memory. So is there any technics, through which I can get the field at some point behind the lens without solving every point in the mesh? I mean, is it possible that I can get the farfield through the nearfield just behind the lens, without solving the Maxwell equation?
Thanks.
3 Replies Last Post 2020/03/13 19:19 JST
Posted: 5 years ago 2020/03/12 0:11 JST
You can compute the radiating far-field using built-in routines in Comsol Multiphysics. Consult the help system. (Note: I am referring to the RF module here.) If you want to evaluate radiated fields outside the finite-element modeled region, but not in the far-field, you may be able to make use of a radiating near-field approach. For one way to implement that, see https://www.comsol.com/community/exchange/672/
Posted: 5 years ago 2020/03/12 11:02 JST
Updated: 5 years ago 2020/03/12 11:04 JST
In case you are asking about the usual near-field to far-field transformation, that's a mature topic discussed in many books and articles. (Here I would like to advertise our recent work "On the Emission Pattern of Nanoscopic Emitters in Planar Anisotropic Matrix and Nanoantenna Structures" available at https://www.researchgate.net/publication/332961578_On_the_Emission_Pattern_of_Nanoscopic_Emitters_in_Planar_Anisotropic_Matrix_and_Nanoantenna_Structures) In particular, the built-in near-field to far-field transformation functionality could be used if inhomogeneities are localized, i.e. not extended to infinity.
However, with the limited description in the post I guess your problem may not be the traditional transform. You can provide more information for others to help.
ZHANG, Pu
School of Physics,
Huazhong University of Science and Technology
In case you are asking about the usual near-field to far-field transformation, that's a mature topic discussed in many books and articles. (Here I would like to advertise our recent work "On the Emission Pattern of Nanoscopic Emitters in Planar Anisotropic Matrix and Nanoantenna Structures" available at https://www.researchgate.net/publication/332961578_On_the_Emission_Pattern_of_Nanoscopic_Emitters_in_Planar_Anisotropic_Matrix_and_Nanoantenna_Structures) In particular, the built-in near-field to far-field transformation functionality could be used if inhomogeneities are localized, i.e. not extended to infinity. However, with the limited description in the post I guess your problem may not be the traditional transform. You can provide more information for others to help.
Posted: 5 years ago 2020/03/13 19:19 JST
Thank you Robert, that's what I'm talking about.
