Ground plane connection of a antenna
Posted 2012/01/16 5:21 GMT-5 RF & Microwave Engineering Version 4.2a 4 Replies
                                                    Hi all,
I am working on a antenna model using the RF module and am wondering if anyone had any thoughts on setting up a shielding condition using a ground plane.
I have a two arm spiral antenna with the arms having a BC of 'perfect conductors', between the arms I've used a 'lumped port'. The arms are modelled below a 50mm cavity which again has a BC of 'perfect conductor' on the bottom and the sides are open. The actual design would have this plane connected to ground.
How should I setup this ground connection in the RF module?
Thanks in advance,
David
Thanks in advance,
David
4 Replies Last Post 2012/01/20 8:49 GMT-5
