How to set user defined boundary condition
I'm now trying to calculate heterojunction. As an example of model library, I use the "Transport of Diluted species" model to calculate. But I want to set a condition that " log(n1)+c1=log(n2)+c2" at the boundary. n1, n2 represent the concentration, c1,c2 are different const depending on material. There are no boundary condition same as this need,so how can I set that boundary condition?
3 Replies Last Post 2012/01/23 22:41 JST
Posted: 1 decade ago 2012/01/18 12:02 JST
I've got some idea about this question. I may use weak constrain, and use 'up' and 'down' function, but I still cannot realize it. How can I set the boundary condition: n1/n2=c, where 'c' is a const and 'n1', 'n2' are the concentration in the two side of the boundary respectively. (i.e. the concentration of the boundary is uncontinuous)
Who have any idea?
THANKS!
I've got some idea about this question. I may use weak constrain, and use 'up' and 'down' function, but I still cannot realize it. How can I set the boundary condition: n1/n2=c, where 'c' is a const and 'n1', 'n2' are the concentration in the two side of the boundary respectively. (i.e. the concentration of the boundary is uncontinuous) Who have any idea? THANKS!
Lechoslaw Krolikowski
Posted: 1 decade ago 2012/01/18 20:15 JST
I think you can use the so called stiff-spring method.
You'll find it in the Separation Through Dialysis example (Model Library - see pdf file).
Andrzej
Hi, I think you can use the so called stiff-spring method. You'll find it in the Separation Through Dialysis example (Model Library - see pdf file). Regards, Andrzej
Posted: 1 decade ago 2012/01/23 22:41 JST
Thank you so much. That document helps me a lot.
