How to Model Liquid-Gas-Liquid interface via membrane ?
Posted 2020/03/26 7:13 GMT-4 Fluid & Heat, Heat Transfer, Chemical Reaction Engineering Version 5.5 0 Replies
Hello!
I am trying to model liquid-liquid membrane contactor for ammonia removal using absorbent. However, I have difficulties in modeling the membrane part!
So I will have diluted ammonia concentration in the inlet, while on the other inlet source I will inject H2SO4 (sulfuric acid), however these 2 will be separated by a membrane. In which the membrane acts only as a barrier, so only diffusion and convection happens.
Since only the gas phase of ammonia can pass through the membrane, I have to change the phase from liquid to gas? and after that I have to convert it back to ammonium (NH4+) to react (yes there will be reaction physics too) with sulfuric acid (H2SO4) producing amonium sulfate (NH4)2SO4
I am confused with how to model these interface (as I have to change liquid phase to gas--and apply gas phase only in membrane--- and change gas that pass through to liquid again), as I tried to find papers regarding this, but nothing is similar!
So any of you have any idea on what kind of physics/boundaries I should apply? I will appreciate anything !!
Thank you!!
--------------------Lia
Hello Asalia
