2012/01/23 18:50 JST
be sure you have the COMSOL add-in active in SW, check the add-in list.
but if you do not use the interactive link (change of geometry within COSMOL, driving SW) then I always use file exchange via generic SW files or Parasolid X_t files. For 2D you need to go through DXF anyhow (SW 2D DXF saving)
2012/01/23 19:14 JST
Thanks. What is SW
Thanks. What is SW
2012/01/23 19:27 JST
Thanks SW - SolidWorks
2012/01/23 19:58 JST
Yes, you got it :)
Yes, you got it :)
2012/04/05 18:48 JST
Hi Ivar Kjelberg
I faced to problem about importing cad data to femlab. I have MRI data, I converted them to STL format with MIMICS software and when I import to femlab after I draw for example a block that encompass the imported object I see below message:
"Error: 2100
Internal error in geometry decomposition."
I try to solve this problem by change the format of file in SW but I can not save it to other format in SW. in some cases that i was successful to change the format( IGS format), femlab did not accept it by following message:
"Error: 3034
The imported file contains no geometry objects."
would you please help me about this problem?
Hi Ivar Kjelberg
"Error: 2100
"Error: 3034
