2012/02/09 15:04 JST
Hi, just build a function() under the material node.
by the way, Do you think this kind of method to model the material removal is ok? because during the laser-material interaction, the laser-material interface change with time(due to the accumulated temperature of the absorbed laser energy). this kind of method do not change the so-called interface, so the temperature at the original boundary(initial laser-material interface) will increase with time, but in fact, at the case of evaporation cutting or something similar, the part of material whose temperature arrive the evaporation temperature. this part of material should be remove.
best wishes to you and your family.
2012/02/13 15:34 JST
hi ,
first of all thank you for replying :) actually my problem is how to make a permanent change in the properties as in once there is a switch in the property , it should remain so even if the material has cooled down.Material properties are a function of temperature so as soon as the temperature falls they switch back again to that of the previous material and i want to avoid this.
i think it is quite a good way to simulate material removal as it is not possible to actually remove elements in COMSOL , by the way do you know any other way to do it ? i am open to suggestions .
hi ,
2012/03/02 11:29 JST
hi ,
firstly, sorry to the later response.
if I have made all clear, you just change the material density into the air density when the temperature pass the evaporation temperature, and while when the temperature cool down (i.e. the laser is turn off), this port of material (whose temperature have passed over than the evaporation temperature once) never turn back into the material density according to the temperature-dependent properties (the general setting is bidirectional instead of one-way). the material properties change way to simulate the material removal, I have tried a few months ago.
let us think if we only consider the temperature or material removal in the pulse width, i.e. the laser is on all the time, and there is no such question you encountered. there material density is set the density properties (this is simple ). but the temperature of the laser-material interaction boundary do not change. theoretically, if this method is right, this temperature is fixed at the evaporation temperature. Is there anything wrong with my model or somethings i miss?
if you are convenient, we can exchange our other IM (instant message) to have a more instant communication so that we can cooperate to work all out. look forward to you reply sincerely.
[QUOTE]
hi ,
[/QUOTE]
2012/03/07 19:50 JST
hi , i have sent you a private message , take a look at that .
Hirendra
Hirendra
