Export Geometry File
I've used Comsol to optimize the geometry of an electrode. I was hoping to export this exact geometry so I can print a mask and then fabricate the electrode. When I've tried to export it, I can only seem to export it as a Comsol file. Is there any way to export it as a .tiff file?
2 Replies Last Post 2012/01/27 16:47 JST
Posted: 1 decade ago 2012/01/27 10:02 JST
I'm replying only in the off-chance that this will help your problem, but it probably won't. You can take a snap shot using the small camera button on the far right. Maybe if you are zoomed appropriately and maintain the correct aspect ratio you will produce a picture file that you can convert to .tiif for a mask. I'm not sure this helps you at all, but I didn't want to keep it to my self in case it did. Best of luck.
Posted: 1 decade ago 2012/01/27 16:47 JST
I find your remark very pertinent, and it should be made possible, pls forward such demands to "support" so they can consider it, hhopefully we will get these functionalities (if not already hidden somewhere) for a future release.
Hi I find your remark very pertinent, and it should be made possible, pls forward such demands to "support" so they can consider it, hhopefully we will get these functionalities (if not already hidden somewhere) for a future release. -- Good luck Ivar
