COMSOL error
Hello I've been problems with COMSOL in a new installation i can't run anything. The window which COMSOL shows says:
The following feature has encontered a problem:
Error: Failed to create a folder to save to\
Would yo mind to help me? Thanks
Oscar
2 Replies Last Post 2012/03/09 1:23 JST
Posted: 1 decade ago 2012/01/30 6:41 JST
For installations, I believe the best is to get help directly from support, or your local rep.
All mine, so far, have all installed smoothless (Win 7 and Linux) without any tweaking
Hi For installations, I believe the best is to get help directly from support, or your local rep. All mine, so far, have all installed smoothless (Win 7 and Linux) without any tweaking -- Good luck Ivar
Posted: 1 decade ago 2012/03/09 1:23 JST
If you are using 4.2 then
go to Options>preferences, and uncheck the "save recovery file" check box
then save and close the COMSOL file, and then re-open again and from then it will not have the error.
If you are using 4.1 then
menu> Options > Preferences > Save, and un-check the "Recovery" check box.
Regards
Faysal
Hi If you are using 4.2 then go to Options>preferences, and uncheck the "save recovery file" check box then save and close the COMSOL file, and then re-open again and from then it will not have the error. If you are using 4.1 then menu> Options > Preferences > Save, and un-check the "Recovery" check box. then save and close the COMSOL file, and then re-open again and from then it will not have the error. Regards -- Faysal
