Help with the model of capillary wicking in a porous material
Posted 2020/04/23 0:59 GMT-4 Heat Transfer & Phase Change 0 Replies
I was trying to use the model provided on Comsol website to work on a time dependent wicking problem in a paper strip where the width is a not constant value (a 6cm-width rectangular wicking pad with a 1cm-width leg below).
Here's the link I found from comsol:
https://www.comsol.com/model/wicking-in-a-paper-strip-79061
I used the same boundary conditions as the above link and I think my mesh should be OK, but there's always an error after running for a while. For some unknown reason, the s value ( the effective saturation) of air (or maybe water) becomes negative.
Except for the geometry, all I changed were the parameters like properties of air and water. Anyone can give me any idea about which part goes wrong and why s becomes negative?
Any help is appreciated. Thanks a lot.
Jing
Hello Jing Yuan
