changing number of boundaries resulted from geometry deformation in the ALE mode
Posted 2010/01/13 13:18 GMT-5 4 Replies
Hi everyone,
I am using 2D ALE module. my model is solved with a COMSOL script which force the solver to stop once the quality of mesh degrade below specified limit. After that I use mesh2geom command to recreate the geometry from deformed mesh and restart solver.
During the process of the geometry change one of the boundary lines shrinks gradually to a point and after that diminishes completely from my geometry. The change of geometry in my code can be just due to the change of the dimensions of the boundaries and diminishing one boundary from the geometry makes trouble in my code and it will stop due to an error.
Is there anyone who knows how I should deal with this problem?
I am thinking about making a new geometry when the mentioned boundary line becomes very small, map my previous results to the new geometry and continue to solve the problem, But I have following questions:
1) In the new geometry, I should merge the shrinking boundary with its nearby boundary. How can I do this?
2) How can I map my results from the previous geometry to the new one?
Thanks for your kind help,
Atieh
Atieh
4 Replies Last Post 2010/01/15 22:07 GMT-5
