coupling a 1D geometry with a 2D geometry.
I wanted to know if it is possible to couple a 1D geometry to a 2D geometry the way I want to.
In fact I am trying to solve a 2D model, but at every point in this model I need to get the solution of a 1D model which depends on the solution of the 2D model at the same point. So I wanted to know if it was possible to make comsol solve the 1D model at every point of the 2D model, in order to solve this 2D model...
I pretty much want to solve the 2D model, put its solution in the 1D model as a constant, solve the 1D model, put its solution on one of the boundary in the 2D model, resolve it... until it converges.
Is there any means to do so? I looked in the comsol guide but could not find anything.
I hope I was clear enough.
Thanks in advance,
Florent.
1 Reply Last Post 2013/06/25 19:09 JST
Hello Florent Allain
Posted: 1 decade ago 2013/06/25 19:09 JST
I want the same problem. I want to couple the boundary of 2D model with th entire geometry of a 1D model.
Did you succed in doing it? how?
Thank you in adavance
Hi, I want the same problem. I want to couple the boundary of 2D model with th entire geometry of a 1D model. Did you succed in doing it? how? Thank you in adavance
