2012/02/15 21:22 JST
have you checked the dependent variables of HT and of TS ?
in fact you are doubling up the work.
HT solves for T but T is already included in the TS.
So from what I understand you only need TS without HT in addition
2012/02/15 21:28 JST
I assume TS means thermal strain module? I've just used the solid mechanics module (solid) and added to the linear elastic material node the thermal expansion node. Because of numerical problems in the heat transfer module some modifications for the values where used, so that the heat transfer module calculates a logarithmic temperature. As input for the thermal expansion node the retransformed temperature is used. This one has the steeper gradients. Does the thermal expansion node also calculate the temperature again?
2012/02/15 21:37 JST
Always check your dependent variables when you add physics.
COMSOl has now in v4.2 included many composed modules "pre-cooked".
But if you mix the complex one you end up duplicating dependent variables. I see a T in both TS and HT so for me you have 2xT, which is one too much. Just disable HT and copy all BC to the corresponding TS heat BC's, it should work ;)
2012/02/15 21:43 JST
Thanks for your quick reply, but I'm not sure, if I understand what you mean. In the solid mechanic module (solid) I use, I cannot find any dependent temperature variable or I'm not able to identify it. I just have a temperature as model input. Does this make this temperature a new dependent variable?
Or are you proposing to forget my present model with solid mechanics and heat transfer module and build a new model with the thermal strain module?
2012/02/15 21:46 JST
Under the main physics node TS you have at the bottom of the window a Dependent variable tab, open it up there you will find the dependent variables (they show also up when you select the physics for a new model). But you can also expand the "Equation view" tab and see what is therein
For me TS is enough: you define the "solid" structural BCs and the Thermal Heat BCs
2012/02/15 21:53 JST
OK, now I opened up a new file with a TS module. There I see also T as a dependent variable for that module, but if I open up the dependent variable tab in the solid module in the other file, there I just see u, v and w but no T. So I still do not understand, why you are still mentioning the TS module, but I will give it a try :-)
2012/02/15 21:57 JST
solid is only u,v,w, while HT is only T but TS is both u,v,w & T
solid itself does not contain the alpha heat exansion in its equation, TS does hence the T
2012/02/15 22:21 JST
Thanks again. I tried to add all the boundary conditions to a thermal strain module but now, there is some new problem with the distributed heat source. I modeled my laser heat source with a weak form PDE and coupled it with a general extrusion operator to my process model. But now I get an error message, that no consistent initial values could be found and that no origin could be found for the extrusion coupling operator.
2012/02/15 23:02 JST
check carefully all nodes and their links, if you make "selections" from your BC id's it's often easier to reconnect all boundaries to the corresponding BC nodes.
but it's difficult for us out here to understand exactly what is wrong, from a few lines explanation, there are so many fields ;)
