Fluid Structure Interaction
Hello
I am trying to model a liquid being injected between 2 thin layers. I am unable to get the liquid to deform the 2 layers and push through to disperse, however.
I am currently getting the error : Inconsistent fluid boundary condition at the fluid-structure interface. The Fluid-Structure Interaction multiphysics coupling requires a Wall feature set at the fluid-structure interface and the Wall Movement Translational velocity set to Automatic from frame. - Node: Fluid-Structure Interaction 1 (fsi1)
Any advice on what I should change would be very much appreciated.
I am currently using the fsi model and have modeled my system as a union.
1 Reply Last Post 2020/06/12 1:49 GMT-4
Posted: 5 years ago 2020/06/12 1:49 GMT-4
UPDATE: I have adjsuted the fluid layer so that it is not blunt at the end at kind of more guided to push through the layers.
The error I get now is: Failed to find consistent initial values. Last time step is not converged.
Also a clarification: The goal is to see how the injected fluid disperses through the 2 layers. It should not disperse very evenly and should cause the initial injection area to deform the most forming a little lump.
Thanks again for your time.
UPDATE: I have adjsuted the fluid layer so that it is not blunt at the end at kind of more guided to push through the layers. The error I get now is: Failed to find consistent initial values. Last time step is not converged. Also a clarification: The goal is to see how the injected fluid disperses through the 2 layers. It should not disperse very evenly and should cause the initial injection area to deform the most forming a little lump. Thanks again for your time.
