Nonlinear bending of an isotropic plate
Posted 2012/02/20 4:44 JST Structural Mechanics 5 Replies
I m trying to simulate a very known benchmark problem which also apears on Reddy and Arciniega's article, ''Tensor-based finite element formulation for geometrically nonlinear analysis of shell structures''.
The problem consists of a plate with width=12 and height=1 (as defined in Comsol), E (module Young) = 1.2*10^6,
poisson ratio is 0 and the thickness of the plate is 0.1. The boundary conditions are fixed constraint at one edge and moment at the opposite edge. (the moment is defined in the Local Edge System and not in the Global Coordinate System).
While in the article Reddy and Arciniega are able to to reach fully circular rotation, using comsol i only can reach much lower rotations when the applied moment is 42. applying moments higher then 42 makes the solution false.
When applying moments lower then 42 , i get rotations that are accurate when comparing to analytical results, but i still wonder why i cant fully replicate what Reddy and Rrciniega did.
thx a lot
Iftah Nudel
thx a lot
Iftah Nudel
5 Replies Last Post 2012/02/23 21:39 JST
