DC coil parametres configuration.
Joao Vicente Goncalves Rocha
Hi all,
Normally when working with coils, I just set up a ring, and then using the area, number of turns and current, I calculate J and add a External Current Density in the model.
Now I have a problem, that needs some DC parametres, like:
-Isolated DC coil inductance, L0;
-Isolated coil resistance, R0;
I searched how to build this in my model, but i couldn't find anywhere.
I would apreciate some sugestions in this.
Thanks for your time!
CYA.
Joao Rocha
1 Reply Last Post 2012/02/28 0:34 JST
Posted: 1 decade ago 2012/02/28 0:34 JST
if you are in 2D or 2D-axi mode you have the advanced coil BC's (I do believe they where there already in v4.1) that allows you to get a better coil representing by defining turns and coil wire etc in teh BC directly, and the BC calculates the voltage current taking all this into account
Hi if you are in 2D or 2D-axi mode you have the advanced coil BC's (I do believe they where there already in v4.1) that allows you to get a better coil representing by defining turns and coil wire etc in teh BC directly, and the BC calculates the voltage current taking all this into account -- Good luck Ivar
