how to show the equation of the physics built by physics builder
I followed the tutorial to build a Thermoelectric Effect Physics. Everything is fine. I also built a instance example based on this physics. I then checked the equation of the physics trying to see how the equations look like, but I found it appears empty. Other build-in physics can all show the format of equations. Is it possible to show the equations so that to make sure all the input equations are correct?
1 Reply Last Post 2020/07/15 7:29 JST
Posted: 5 years ago 2020/07/15 7:29 JST
It should be there. May I suggest you post your model to the forum so that others can take a look at it. Perhaps they can find where your equation is hiding.
