How To Find Specific Geometry Name/Identifiers in MATLAB with COMSOL
I'm using COMSOL with MATLAB to build a model which can be altered based on inputs in the MATLAB script to change the geometry and applied voltages in COMSOL. I've been able to change the geometry as needed, however, I'm having trouble with setting the selection for terminals where the voltage would be applied. For example, normally in the COMSOL GUI you would select the terminal by selecting the relevant geometry in the display window. In this case, I need a way to get the "name/number" or identifier of the relevant edge of the electrodes I've created in the MATLAB so I can use that as an input to set my voltage terminal.
Thank you!
3 Replies Last Post 2020/11/05 7:22 GMT-5
Jeff Hiller COMSOL Employee
Posted: 5 years ago 2020/07/27 15:52 GMT-4
Hello Alisha,
This blog post addresses your question, I believe.
Jeff Hiller
Hello Alisha, [This blog post](https://www.comsol.com/blogs/manually-work-entity-numbers-selections) addresses your question, I believe. Best regards, Jeff
Posted: 5 years ago 2020/10/27 14:03 GMT-4
Hello Jeff,
Is it possible to go one step further and obtain the IDs/coordinates of mesh nodes on a certain geometric entity like an edge?
Thanks, Mohamed Abdelhamid
Hello Jeff, Is it possible to go one step further and obtain the IDs/coordinates of mesh nodes on a certain geometric entity like an edge? Thanks, Mohamed Abdelhamid
Posted: 4 years ago 2020/11/05 7:22 GMT-5
Updated: 4 years ago 2020/11/08 4:09 GMT-5
Use mphgetcoords to get coordinates if you know the entity number
Use mphselectbox or mphselectcoords to get the entity numbers if you know (something about) their coordinates.
If you need more info then please exactly what info you have and what you would like to get.
Lars Gregersen
Comsol Denmark
Hi Use mphgetcoords to get coordinates if you know the entity number Use mphselectbox or mphselectcoords to get the entity numbers if you know (something about) their coordinates. If you need more info then please exactly what info you have and what you would like to get.
