                                2 decades ago
                                2009/08/06 19:06 GMT-4
                                                    I am having the same problem. When using integration coupling variables (for global destination, use for global equation) I get the same error. Why doesnt it say which value is not defined?
                                2 decades ago
                                2009/08/07 4:30 GMT-4
I think that the problem is due to the definition of the expression. Please check if the expression you try to integrate is correclty defined "inside" the domain. As example, if you ask comsol to calculate the exspression "u" in the point x0,y0, which is outside the domain, comsol returs the error "undefined value found"
I hope this may help you
Pasquale
Pasquale
                                2 decades ago
                                2009/12/23 17:06 GMT-5
                                                    so then how to include those points inside the domain?
thanks.
Pasquale
thanks.
[QUOTE]
Pasquale
[/QUOTE]
                                2010/11/12 6:26 GMT-5
                                                    I'm having the same problem. It seems that the mesh creates points which should be at the boundary of my model, by is outside the model domain. The problem occurs when I attach perfectly matched layers to my model. Removing these, removes the problem, but then I don't get the result I'm after.
                                2011/03/15 17:15 GMT-4
                                                    I also come across this problem now. Have you guys known how to solve it? Can you share your method with me? Thx a lot!
