FSI Problems
Posted 2012/03/06 8:48 GMT-5 Mesh, Studies & Solvers Version 4.2, Version 5.2 4 Replies
I am new to COMSOL and currently have a time dependent FSI model with numerous problems. The model is that of a fluid flow over an elastic material that should (hopefully) deform similar to the example 361 with different geometry. I used this example model for the basis of my model and am now having problem changing some of the values.
I am not able to reduce the youngs modulus of my model from 1e5 to 2e4 or even 9e4. When
doing this I recieve complaints that the non linear solver did not converge.
I also can not put in a simple equation for the velocity of u=a*t where u is the velocity
of the flow, a is an acceloration. When entering this into my model I get an error that
COMSOL could not find consistent initial values. I can get the model to run, however, if
I change the velocity equation to that given in example 361 on the website for u_in.
I have also tried automatic remeshing as I am using COMSOL 4.2, however, I coould not get
this to work either as there is NO dynamic help on this. I have also tried remeshing by
hand when the model experiences a poor mesh quality but then obtained errors about
inconsistancies in the stiffness matrix.
I will be greatful for the help
Kelly
Kelly
4 Replies Last Post 2016/06/20 3:13 GMT-4
