The current on a section of a 3D model
hello,
i have a problem with the calculation of current in one section of a 3D model (v.4.2).
My model is imported with LiveLinks SolidWorks.
I have a three-dimensional model on which inject current from two electrodes. I would like to calculate how to distribute the current in the model and, in particular, how much current is distributed over a section given.
How do I calculate it?
Thank you so much.
Chiara
2 Replies Last Post 2012/04/21 3:57 JST
Posted: 1 decade ago 2012/03/12 17:32 JST
I believe you are looking after the integration of the current over a boundary (easiest adda Definition coiupling boundary integration, then add a Results Derived values and calualte the integral of the current density.
Or plot it directly versus time if you are in time solving
Hi I believe you are looking after the integration of the current over a boundary (easiest adda Definition coiupling boundary integration, then add a Results Derived values and calualte the integral of the current density. Or plot it directly versus time if you are in time solving -- Good luck Ivar
Posted: 1 decade ago 2012/04/21 3:57 JST
I have a similar problem, I need to calculate the current through a 3D wire at different sections. I tried to calculate a surface integral of the current density from derivated values.
Now I need to create a plot showing the current values against a spatial parameter and I don't know how to define it.
The wire has a semicircular shape and I calculate the current on sections at 0°, 30°,60°,90°,120°,150° and 180°.
I would like to make a plot with current values on the y-axis and the corresponding degrees on the x-axis.
Could anyone help me?
Hi I have a similar problem, I need to calculate the current through a 3D wire at different sections. I tried to calculate a surface integral of the current density from derivated values. Now I need to create a plot showing the current values against a spatial parameter and I don't know how to define it. The wire has a semicircular shape and I calculate the current on sections at 0°, 30°,60°,90°,120°,150° and 180°. I would like to make a plot with current values on the y-axis and the corresponding degrees on the x-axis. Could anyone help me?
