2012/03/13 16:29 JST
not sure why, but when I remake it (in my 4.2a it works OK, but you should turn of the "include inertial terms for the Solid" and use quasi static to avoid the transients at the start, as well as the self oscilaltory terms, in this way you neglect the (rho*d^2_u_/dt^2) terms
2012/03/13 18:17 JST
You are right, I just rebuild it myself from scratch using the same settings and it's working. I must have changed something inadvertently.
Thanks for checking I'm not going crazy just yet.
2012/03/13 20:51 JST
one thing I forgot to note down in previous message, you where in meters scale and not [um] that has probably also something to do with the issue, the force was somewhat small ;)
Scaling again 1:1'000'000 linear scaling is too much for good precision on solving models even with double floating today, when are the 256 bit floating point processors coming ?
2012/04/04 5:39 JST
Dear Sir
I am running into the same type of error and cannot figure out how to use "quasi static" initially. I have attached the model. Its a 2D FSI where the fluid is pushing the viscoelastic cell . Please suggest
Thank you
Ishan
[QUOTE]
[/QUOTE]
Dear Sir
Thank you
Ishan
2012/04/05 23:30 JST
Your idea is similar to the Fluid-Structure Interaction model. So I suggest you check that one first.
