Error using multiple Parameter for Sweeps
Hello Comsol-Community,
i get an error when i try to calculate a study with two Parameter Sweeps. The error say something like "Parameter list dont have the same length for the thin sweep type" (Direct german translation "
Friendly Greetings
2 Replies Last Post 2020/09/17 4:54 GMT-4
Posted: 5 years ago 2020/09/16 7:36 GMT-4
Updated: 5 years ago 2020/09/16 7:36 GMT-4
There are two ways of running sweeps with multiple parameters:
  • All combinations ; then parameter list for each parameter can have different lengths N1, N2, N3, ... because all N1 × N2 × N3 × ... cases will be computed
  • Specified combinations ; then all parameter lists must be of equal length N, because only N combinations will be computed, using the 1st value of each list, then the 2nd, etc. until the N-th
You must have set the sweep type as "Specified combinations" and your parameter lists have different lengths. So depending on what you want you should switch to "All combinations" or equalize the lists' lengths.
Hello, There are two ways of running sweeps with multiple parameters: * All combinations ; then parameter list for each parameter can have different lengths N1, N2, N3, ... because all N1 × N2 × N3 × ... cases will be computed * Specified combinations ; then all parameter lists must be of equal length N, because only N combinations will be computed, using the 1st value of each list, then the 2nd, etc. until the N-th You must have set the sweep type as "Specified combinations" and your parameter lists have different lengths. So depending on what you want you should switch to "All combinations" or equalize the lists' lengths.
Posted: 5 years ago 2020/09/17 4:54 GMT-4
Thanks! For the quick answer!
