Robert Koslover
Certified Consultant
5 years ago
2020/09/18 1:38 JST
- Well, it's not much bigger, is it? And the materials in your design have no losses.
- I also suggest you compare the realized gain to the directivity.
- Consider also using a finer mesh.
1. Well, it's *not much* bigger, is it? And the materials in your design have no losses.
2. I also suggest you compare the *realized* gain to the directivity.
3. Consider also using a finer mesh.
5 years ago
2020/09/18 2:27 JST
Hi Robert,
Should I accept this situation as they are almost same but the small calculation errors causes this result. If so, I won't worry about it.
I had done it. Realized gain = 7.3393, directivity = 7.3388. The gain is winner again :).
The results obtained with extremelly fine meshes:
Maximum directivity, dB: 7.3388
Maximum gain, dB: 7.4306
Maximum realized gain, dB: 7.3393.
Thank you.
Hi Robert,
Thank you.
