Quicker method for saving slice data after parametric study of two or more parameters
Posted 2020/10/08 16:05 GMT-4 Chemical, Heat Transfer & Phase Change, Results & Visualization Version 5.5 0 Replies
Hey everyone,
I have done parametric sweep of two parameters in my study, let them be Temperature and Radius. After the sweep, I use slicing of my geometry to obtain the temperature profile over the geometry. I have a set of slice plots of 32 different radius points and 51 different plots for temperature points, therefore I have to manually export each slicing dataset for parameter combinations of 32x51 = 1632 parameter sweep dataplots. I need to export this data into excel or csv files. Is there any easier and efficient way to do this?
If all of the datapoints (Lets say 51 points of temperature) for one of the parameter data for slicing can be congregated into one set of data or file while saving the other (32 points for radius) individually, even that would be easier. Is it possible?
Thanks for the help
Puneet
Hello Puneet Koli
