Hello Michele Comunian
2012/09/16 17:52 GMT-4
Dear Michele,
Have you done any progress in this model?
In fact I'm starting the same kind of simulation (use emw as heating source) and I have many option to do that but I can't find the right way to do it.
I want to model the heat induced by a laser beam at a fixed wavelength on a thin metallic surface. Most of the models that i found doesn't account for the wavelength, it just represent the exchange of power which is far away from what I aim to:
www.comsol.com/showroom/gallery/12317/
www.comsol.com/papers/2685/ (Many papers from this group)
I tried to use the microwave heating module in the visible, it's very hard to make any calculation converge.
I also tried the emw + Heat transfer, the calculation converged but without any heat.
I open to any suggestion.
Karim
Dear Michele,
http://www.comsol.com/showroom/gallery/12317/
http://www.comsol.com/papers/2685/ (Many papers from this group)
Karim
2012/09/18 11:03 GMT-4
Hi Michele and Karim,
I am trying a very similar approach as both of you, maybe we can figure this out. I want to use a mode analysis to solve for the fundamental mode of my waveguide structure, then use the power loss density as the heat source. I'm having the same problems.
Michele, I was having similar errors with the frequency. Mine was saying couldn't solve the Jacobian for variable 'freq' i think. I added a frequency domain solve with basically the same frequency that I mode solved for, and this seemed to get it past that.
On to the heat solving in study 2. I typically get 0 solution here using the emw + heat transfer, with a stationary or time-dependent study. What's more confusing is that if you plot the "heat source" from solution 2, you would expect it to plot the "power loss density" from study 1, but it gives that exact error you posted. So I believe the problem is with the heat source. It's not clear to me how it comes up with a power loss density for mode-solving, since I can't specify a power to begin with.
I'm actively working on correcting these issues, and will keep you updated. Any suggestions would be welcome!
-Kevin
-Kevin
2012/09/19 8:47 GMT-4
My first suggestion would be to use a PORT excitation in which you can specify an input power.
In any case, I'm not really sure that it's possible to make this kind of simulation with comsol, or I still don't know where to specify a spectral emissivity!
I will let you know if I progress in this direction.
Karim
Karim
