simulate AC voltage phase shift due to medium property discontinuity
Hi All,
I am rather new to COMSOL so I have attached my model just in case I accidentally confused you.
I want to simulate the phase shift of AC electric signal due to discontinuity of medium property. So I have basically two electrodes(one grounded, another applied an AC potential ==>V*e^(jwt)) in a tank of water. I want to see the phase shift caused by the introduction of material of different dielectric property.
I have used the AC/DC module and ran a frequency analysis at 1KHz and 100KHz. The boundary condition at the electrode is set to 4 and GND. At two different frequencies, i do see different field lines. Here comes the questions
1. when I set the BC to be 4V and use frequency domain analysis, does COMSOL consider the potential to be time variant?
2. How can I see the complex voltage from the frequency simulation?When I click on the plot, i am always getting real voltages. I want to see how much the phase has been changed due to the introduction of the object.
I am not even sure I am using the correct model. But by varying the frequency, I clearly see the change of object property. From insulating to conducting? But why can't I have the complex potentials?
Thanks a lot!
2 Replies Last Post 2012/03/20 12:31 GMT-4
Posted: 1 decade ago 2012/03/20 6:31 GMT-4
according to your questions:
1. Yes a harmonic voltage is applied
2. The field quantities are complex, just use the real() and imag() operators to get the complex components.
Cheers
Edgar
Hi, according to your questions: 1. Yes a harmonic voltage is applied 2. The field quantities are complex, just use the real() and imag() operators to get the complex components. Cheers Edgar
Posted: 1 decade ago 2012/03/20 12:31 GMT-4
Thanks Edgar, That is very helpful
