Robert Koslover
Certified Consultant
5 years ago
2020/11/11 10:58 JST
Updated:
5 years ago
2020/11/11 11:00 JST
First, I'll assume you are doing an RF model in frequency-domain mode. You may also notice that you had to specify a characteristic reference impedance. The default is 50 ohms. Bear in mind that the voltage you are specifying is the peak voltage, not rms. So the power becomes
. Note that if you have an impedance mismatch (which is very likely, if you don't put in effort to choose the reference Z to match), then your actual forward power will be less.
250 V into 50 ohms would thus be 625 Watts.
First, I'll *assume* you are doing an RF model in frequency-domain mode. You may also notice that you had to specify a characteristic reference impedance. The default is 50 ohms. Bear in mind that the voltage you are specifying is the *peak* voltage, not rms. So the power becomes V^2/(2*Z_r_e_f). Note that if you have an impedance mismatch (which is very likely, if you don't put in effort to choose the reference Z to match), then your actual forward power will be less.
