Magnetic field distribution in and around a conductor
Hello everyone I am new to COMSOL and need help on how to approach this problem
Find the magnetic field distribution in and around an infinitely-long, current-carrying conductor in air. Also find the distribution of current density, J in the conductor. Given: current, I=10 A, conductor diameter, d=10 mm, frequency, f=0 (direct current, d.c.).
Thanks everyone in advance
3 Replies Last Post 2020/11/16 6:07 JST
Posted: 5 years ago 2020/11/13 6:27 JST
Updated: 5 years ago 2020/11/13 7:07 JST
That sure sounds a lot like a "homework problem" to me... Anyway, I suggest you start with a 2D axisymmetric model using the AC/DC module (assuming you have that) using either the Magnetic Fields (mf) or Magnetic and Electric Fields (mef) formulations, with a Stationary study. But you could attack it other ways too, and some might be better or more elegant. Strictly speaking, it is only a 1D problem, since there is only a radial dependence present (in a polar coordinate system). So I suspect others here can offer you even simpler approaches than I have suggested.
Posted: 5 years ago 2020/11/13 23:36 JST
Thanks for your help
Yes this is a homework problem. I am brand new to COMSOL so I need to familiarise myself with the basics. My professor recommended me to ask for help here.
>That sure sounds a lot like a "homework problem" to me... >Anyway, I suggest you start with a 2D axisymmetric model using the AC/DC module (assuming you have that) using either the Magnetic Fields (mf) or Magnetic and Electric Fields (mef) formulations, with a Stationary study. But you could attack it other ways too, and some might be better or more elegant. Strictly speaking, it is only a 1D problem, since there is only a radial dependence present (in a polar coordinate system). So I suspect others here can offer you even simpler approaches than I have suggested. Thanks for your help Yes this is a homework problem. I am brand new to COMSOL so I need to familiarise myself with the basics. My professor recommended me to ask for help here.
Posted: 5 years ago 2020/11/16 6:07 JST
You might find the discussion in the following paper interesting, as well: http://www.it.uu.se/edu/course/homepage/projektF/vt03/projekt3.pdf Good luck.
You might find the discussion in the following paper interesting, as well: [http://www.it.uu.se/edu/course/homepage/projektF/vt03/projekt3.pdf](http://) Good luck.
