Rigid connectors VS Fixed constraint
Likitha Thimmaraju Girijadevi
Im simiulating a test set up for random vibration analysis, I fix my test object onto the fixture using M5 screws and use bolts to lock my fixture onto the test bed.
Would rigid connectors be a best option between the fixture and test bed or fixed constraint be suitable?
Thank you
2 Replies Last Post 2021/01/04 9:33 JST
Posted: 5 years ago 2020/12/23 1:10 JST
Hi, Likitha,
I know that you already have the answer, but for other readers:
Typically, you apply the excitation as a volume load, with the attachments to the fixture being fixed. The only reason to use a more complex modelling approach with rigid connectors is that you want to evaluate the reaction forces acting on the fixture bolts.
Henrik Sönnerlind
COMSOL
Hi, Likitha, I know that you already have the answer, but for other readers: Typically, you apply the excitation as a volume load, with the attachments to the fixture being fixed. The only reason to use a more complex modelling approach with rigid connectors is that you want to evaluate the reaction forces acting on the fixture bolts.
Posted: 5 years ago 2021/01/04 9:33 JST
Thank you so much Hendrik :)
