Result is not symmetric in y-dir while geometry and boundary conditions are symmetric.
Posted 2012/03/31 14:26 GMT-4 Fluid & Heat Version 4.2a 3 Replies
I've tryed to see how much reaction forces exerted on the structure within the water flow tunnel.
Instead of modelling half of the structure in y-coordinate, I just model all in 3D.
Current is flowing in x-direction, and geometry of structure and tunnel is symmetric in y-direction.
Regardless of any changes in boundary conditions, symmetric boundaries, flowing direction, mesh size, turbulent or larminar, the reaction force on the structure and the pressure on the structure by flow current are not symmetric with respect to y direction.
for example, in the atteched file, I have reaction force in y-dir on the structure is -1887.67 N with the setting that + x_dir flowing. It is fairly small value compared to x direction force, -9.24e6 N.
Now, if I just change the flow direction to - x_dir(minus), I can get similar values of reaction force in x,z direction. However in y-direction, I get -22926.8N.
the reaction forces in y-direction are varying a lot by every changes and also it always comes up in (-),minus, value.
How do I treat these unexpected results? Every things in y direction are symmetric, but I can't get rid of the unbalanced numbers in y-direction.
Can anyone explain this results from COMSOL?
Thanks in advance,
p.s. I used Volume integration in Derived Values node in Results to get the reaction forces
Thanks in advance,
3 Replies Last Post 2012/03/31 20:03 GMT-4
